How to split polygon by area?
  • Apr 13, 2023 3:55 AM UTC
  • 518 views
I have some polygon features. Imagine one has area 100 units. Now I want a polygon having area 30 units to be split from this. Similarly I have many polygons and a list of areas. How do I split a polygon into two based on area?
evieatsafe
Forum|alt.badge.img+28
  • Apr 17, 2023 7:28 PM UTC
Hi @rnwitindia​ I'm not really sure what your expected outcome would be but there's a couple of options you could take. If you have defined areas that you would like split then you could use a Clipper. You could also use a Chopper which divides your input features based on the number of vertices. There are many spatial analysis methods in FME, you can check out most of them here: https://community.safe.com/s/article/how-do-i-do-that-in-fme
geomancer
Forum|alt.badge.img+71
  • Apr 18, 2023 8:02 AM UTC
One very simple way is to use a Scaler and an AreaOnAreaOverlayer.
Split_by_Scaling
