How to solve "Invalid longitude value given for projection origin"?
  • Aug 16, 2022 4:18 PM UTC
  • 7 replies
  • 218 views
I'm using a coordinate system that is not in FME’s Coordinate System Gallery. I added a custom coordinate system by creating a new .fme file and using the online tool. When I use it in my FME model it give me the message: "Invalid longitude value given for projection origin".
My .fme file has this information:
COORDINATE_SYSTEM_DEF PTRA08-UTM/ITRF93 \\
  DESC_NM "PTRA08 / UTM zone 26N EPSG:5015" \\
  GROUP EUROPE \\
EL_NAME GRS1980 \\
  ORG_LAT 0 \\
  PARM1 -27.0 \\
  PROJ UTM \\
  QUAD 1 \\
  SCL_RED 0.9996000000 \\
  SOURCE "https://www.dgterritorio.gov.pt/geodesia/sistemas-referencia/regioes-autonomas/PTRA08-UTM-ITRF93" \\
  UNIT METER \\
  X_OFF 500000 \\
  Y_OFF 0
I think the error is in PARM1, but I think it's ok... -27
Best answer by geomancer
Studying the documentation on Local Coordinate Systems, it appears that for proj UTM you must provide PARM1 ("UTM zone number. Note that this must be an integer value between 1 and 60, even though it is carried in a variable of the double type.") and PARM2 ("The hemisphere of the zone. Use a positive value for northern hemisphere and a negative value for the southern hemisphere.")
Also the documentation states that the sting SOURCE has a maximum length of 63.
There may be other issues.
itsmatt
Forum|alt.badge.img+48
  • Aug 16, 2022 7:56 PM UTC
Have you tried renaming PARM1 to ​ORG_LONG?
geomancer
Forum|alt.badge.img+71
  • Aug 17, 2022 12:01 PM UTC
Probably should be ORG_LNG.
I tried that and the parameter was accepted but the error persisted
geomancer
  • Aug 17, 2022 2:56 PM UTC
Thank you! I think that this error is solved..
Now it's a different error: "A fatal error has occurred. Check the logfile above for details
is not a supported projection."
geomancer
  • Aug 18, 2022 8:06 AM UTC
I see you have modified the text in your original post. Assuming this is your current setup, you are still missing PARM2.
The settings below work for me (at least I can assign the coordinate system to a test object with the CoordinateSystemSetter), but it may not be correct or complete for your purpose:
GROUP EUROPE \
EL_NAME GRS1980 \
PROJ UTM \
PARM1 -27 \
PARM2 1 \
UNIT METER \
X_OFF 500000
