How to set up web connection to fme server 2023?
  • Aug 24, 2023 8:20 AM UTC
  • 6 replies
  • 162 views
limo
Forum|alt.badge.img+8
I have a workbench where I download data from Arcgis online.
For this I use the transformer "ArcGIS_AP_FileGDBExport". This works fine with FME Form. But I will use this workbench inside fme flow and during the upload comes the following warning:
If I ignore the warnings the workbench is not working! How can I set up web connections correctly in fme flow?
Best answer by limo
What are those connections connecting to? It looks like you're using parameters to have the user select them and that's throwing the publish wizard off for some reason, then again the error says it's missing or not supported...
I am not sure I need only the Web connection for ArcGis online used by the transformer "ArcGIS_AP_FileGDBExport" or "ArcGISOnlineConnector".
I think the token is only valid for a limited time. The docu says the OAuth-token created by authorization code is valid for 30min. This would apply to me. The process is working in fme flow for 30min. After this time the connection is not valid.
Maybe I can try "ArcGISOnlineTokenGetter" to gt for every process a new token for the AGOL connection!
Forum|alt.badge.img+63
limo
  • Aug 29, 2023 8:16 AM UTC
siennaatsafe
Forum|alt.badge.img+12
Hi @limo,
This looks like a bug to me. What version of FME Form and Flow are you using? Would you mind posting your workspace? I wouldn't need the data, I'm just curious to see how your using the connection in the workspace.
limo
  • Aug 30, 2023 5:45 AM UTC
We are using FME Form 2022.1.3.0 and FME Flow 2023.0.1. You will find an excerpt of the workbench attached. The web connection can be tested successfully! But where do I have to insert the code?
siennaatsafe
Hi @limo,
That doesn't look quite right have you followed the steps here? https://community.safe.com/s/article/How-to-Create-an-ArcGIS-Online-Web-Connection
Maybe confirm that the FME Flow Web Service has a redirect URI set.
I did take a look at your workspace. In the future, I would ensure that the Form version matches the Flow version. Compatibility issues can arise this way.
I suspect there is something in the custom transformer that FME doesn't like or isn't picking up. I couldn't access it as it is password-protected. However, if you make a support case with your reseller they should be able to determine the cause.
limo
  • Sep 4, 2023 12:05 PM UTC
hi @siennaatsafe​ ,
thanks for your answer. I followed these instructions on the website you have specified. But unfortunately it doesn´t work. I will rewrite the process so that I generate a token first. After that I download the data from ArcGISOnline over the API. For this I use the HttpCaller with the new generated token!. So for this process I no longer need a web connection.
