How to set up Athena query? (AmazonAthenaConnector)
  • Jun 22, 2022 8:33 AM UTC
  • 56 views
Hi all,
I'm trying to use the AmazonAthenaConnector but I'm not sure what the correct settings are.
imageFirstly, what do I need to put in the Bucket / Path fields?
Secondly - when I try adding values in these field and run the translation I'm getting the following error:
Invalid bucket name "all-product-athena-result/": Bucket name must match the regex "^[a-zA-Z0-9.\\-_]{1,255}$"
Error encountered while calling method `input'
AmazonAthenaConnector_2_CALLER (PythonFactory): PythonFactory failed to process feature
Thanks,
Ed
JennaKAtSafe
Forum|alt.badge.img+9
Hi @edhere. The Bucket and Path are highlighted in red meaning they are required parameters. Looking at the documentation for the AmazonAthenaConnector the bucket and path is used to save the results of the query.  Looks like you should be able to navigate to the AWS S3 console and click on your bucket's name to find this. Hope this points you in the right direction!
