How to set up a creation of pdf/shp for each DB-row sent with emailer
  • May 8, 2023 11:52 AM UTC
  • 35 views
I have an MSSQL database, where new rows will be added on and off. I have setup a workspace that will be run nightly, that checks the database for rows with null in the field "email_sent_with_data" and sends it in a beautifully formatted email and it works wonderfully.
However, I would like to send along a map, either a pdf or a shapefile or similar containing the three geometry columns in the row. Any ideas for solutions to this problem?
nielsgerrits
Forum|alt.badge.img+67
Use a FeatureWriter to write a shape zip, then use the outputport of the FeatureWriter to initiate the Emailer.
If you don't want to keep the zip you can use a TempPathnameCreator to write the zip to a temp folder, but I advise to add that part after you have it working as debugging temp files is harder.
