How to set reference system for {x},{y},{z} PNG raster images
  • May 31, 2019 1:31 PM UTC
  • 195 views
I have a set of PNG images downloaded from a service like:
http://tile.openstreetmap.org/{z}/{x}/{y}.png
The images are named:
etc.
How can I combine these image in FME and project them correctly?
Best answer by jdh
OSM uses a slippy map.
To go from tile numbers to lat long use the following equations:
n = 2 ^ zoom lon_deg = xtile / n * 360.0 - 180.0
lat_rad = arctan(sinh(π * (1 - 2 * ytile / n)))
lat_deg = lat_rad * 180.0 / π
This returns the NW corner of the image. You can use xtile+0.5 and ytile+0.5 to get the center of the tile
jdh
Forum|alt.badge.img+41
  • May 31, 2019 1:54 PM UTC
jdh
  • May 31, 2019 4:47 PM UTC
Personally I would calculate all four corners and use the RasterGeoreferencer  and then the RasterMosaicker, then use a CoordinateSystemSetter to define the projection as EPSG 3857.
  • Jun 3, 2019 6:53 AM UTC
Works like a charm, thank you!
I ended up not using the RasterMosaicker as it opened too many files which would require to use the Mosaicker in two steps. Instead I vectorized each raster individually and combined the results at the end, which probably also is faster for my scenario.
