How to send files from 1 workspace to another
  • Feb 11, 2013 9:41 AM UTC
  • 5 replies
  • 103 views
sigtill
Forum|alt.badge.img+25
I have a scenario with 3 chained workspaces on FME Desktop. Ie the user starts workspace 1, which starts workspace 2, which starts workspace 3. Workspace3 uses data (from a large textfile) that is generated in workspace.
At the end the user gets some files created in workspace 2 (PDF and TXT) and some files generated in workspace 3 (TIF).
When I try to port this to FMEServer I struggle to send links to the files to download between multiple workspaces. Any workaround to this issue? I can not make 1 workspace instead of 3, due to the fact that I have to process completely different based on the writing to PDF / TXT from workspace 2.
fmelizard
Forum|alt.badge.img+22
  • Feb 11, 2013 5:06 PM UTC
Have you tried what I call the "Dave" method - after Dave Campans who came with it?
http://fmepedia.safe.com/articles/How_To/Chain-Jobs-in-FME-Server
Although I think I understand the problem - you want it all packaged up in one zip file for the file download?
sigtill
  • Feb 11, 2013 5:25 PM UTC
Hi Ken!
Thanks for the swift reply. Although I though I have watched all the FMEPedia-articles I havent looked at this one. After looking at it shortly it might help me in the right direction.
A comment to your last paragraph - to clear my goal: There is a mylonglogfile.txt generated when Workspace2 is finished. I want to READ this (by using the AttributeFileReader) in Workspace3. Is this more clear?
A simplified approach would be:
Workspace1.fmw:
-Creator
-AttributeCreator(myParam='hello from WS1')
-AttributeFileWriter(myParam, to file mylonglogfile_TODAYSDATEANDTIME_UNIQUE.txt)
-Workspacerunner(Worspace2.fmw)
Workspace2.fmw
-Creator
-AttributeFileReader(mylonglogfile_TODAYSDATEANDTIME_UNIQUE.txt)
-CustomTransformerToAddText(replace 'hello from WS1' with "hello from WS2')
-WRITER (mylonglogfile_TODAYSDATEANDTIME_UNIQUE.txt) and send link to user
sigtill
  • Feb 13, 2013 11:17 AM UTC
@KenAtSafe Would be nice to have som very complex FMEServer examples on todays and tomorrows Webinar!
  • Feb 13, 2013 10:21 PM UTC
I've had success with the "Dave" method (thanks Dave) but it is a nasty thing to manage, trace errors, etc.  A more elegant method would be much appreciated.
I've found the Recorder and Player transformers useful to pass data between workspaces after the initial read.  I hope that helps.
sigtill
  • Feb 14, 2013 4:47 PM UTC
Thanks Andy!
