How to select specific elements with XMLUpdater?
  • Jul 1, 2022 3:51 PM UTC
  • 145 views
gerard
Participant
Hello,
I have to update DATE value in XML file and I use XMLUpdater transformer. It works perfect if it is only one date value.
I have problems updating date field for coleListValue="publication" in the situation that shows the following example:
           <CI_Citation>
               <date>
                  <CI_Date>
                     <date><gco:Date>2006-07-01</gco:Date></date>
                     <dateType<CI_DateTypeCode codeList="myCodelists.xml" codeListValue="creation"/></dateType>
                  </CI_Date>
               </date>
               <date>
                  <CI_Date>
                     <date><gco:Date>2014-07-11</gco:Date></date>
                     <dateType><CI_DateTypeCode codeList="myCodelists.xml" codeListValue="revision"/></dateType>
                  </CI_Date>
               </date>
               <date>
                  <CI_Date>
                     <date><gco:Date>2016-03-17</gco:Date></date>
                  </CI_Date>
               </date>
               <date>
                  <CI_Date>
                     <date><gco:Date>2020-01-22</gco:Date></date>
                     <dateType><CI_DateTypeCode codeList="myCodelists.xml" codeListValue="publication"/></dateType>
                  </CI_Date>
               </date>
            </CI_Citation>
I have checked information at [1] and I have tried some solutions like [2] but nothing works, could you give some advice?
[1] http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/xmlupdater.htm
[2] XML path = /MD_DataIdentification id="ID0003"/citation/CI_Citation/date/CI_Date/datetype/CI_DateTypeCode[@codeListValue="publication"]/gco:Date
Best answer by debbiatsafe
Hello @gerard​
The XPath you shared does not work for the structure of your XML file. The XPath selects the node CI_DateTypeCode where the codeListValue attribute is "publication" and this part works. However, gco:Date is not a child of this node.
In your case, you would want to use the ancestor axes to update the gco:Date node:
//CI_Date/dateType/CI_DateTypeCode[@codeListValue='publication']/ancestor::CI_Date/date/gco:Date
Note that I have removed /MD_DataIdentification id="ID0003"/citation/ from your XPath as those are not included in the XML snippet.
debbiatsafe
Forum|alt.badge.img+24
  • Jul 5, 2022 5:51 PM UTC
Hello @gerard​
gerard
Participant
  • Participant
  • Jul 8, 2022 8:35 AM UTC
Hello @gerard​
Thanks a lot @debbiatsafe​, as you said /ancestor is the solution. Thanks!
