How to select bands in a CSAR raster file ?
  • Aug 12, 2022 7:39 AM UTC
  • 101 views
The obvious transformers (Rasterselector, RasterBandRemover, RasterBandKeeper) do not give the desired output. No errors are generated but all bands of the CSAR raster file are still present after processing. The bands seem to be hidden but I can not find a way to make them available for processing.
Best answer by danminneyatsaf
Hi @yasminvb​ you can use a RasterSelector to select which bands you want to modify, and then you can use a RasterBandRemover to remove the bands previously selected.
If you're still have trouble, would you be able to send a copy of your source CSAR raster file? You can share it here or you can upload it to our Safe Software FTP if it's confidential.
danminneyatsaf
Forum|alt.badge.img+13
  • Aug 16, 2022 12:56 PM UTC
Thank you! This combination gives the desired output. I do wonder why I can still see 9 bands when I look at the output when I only keep 3 but when the file is written to csar and read again it contains the 3 selected bands. ​
