How to run only 1 part of a workspace?
I have a test workspace which im using to build a workflow. I find it quite irritating to select the transformers which I DONT want to run, so I can test the results of others. Is it possible (other than having to disable transformers) to have multiple workspaces? Is there not a way to just define which areas should run by selecting them?
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
