How to rotate a polygon around an axis?
arthy
Forum|alt.badge.img+8
Hello,
I have a 3D polygon.
I would like to perform a rotation of that polygon around an axis with a specific angle value given a defined x,y,z point.
How can I do that inside a python caller?
Thanks
erik_jan
Forum|alt.badge.img+19
  • April 18, 2019
Have a look at the 3DRotator transformer.
The functionality seems available, so why use Python?
jdh
Forum|alt.badge.img+28
  • April 18, 2019
If you absolutely need to use python, since there is no build-in method to rotate in 3D like there is in 2D, you can use
fmeobjects.FMEFeature.performFunction(str) or
fmeobjects.FMEFactoryPipeline
I'm not sure which, as the 3DRotator does not appear to be in the functions and factories documentation
https://docs.safe.com/fme/html/FME_FactFunc/index.html
EDIT: It looks like the 3D rotator uses the @affine function
