How to return a variable amount of characters in the middle of a string
  • Feb 22, 2018 12:13 AM UTC
  • 5 replies
  • 130 views
I need to extract a variable amount of characters from a string and would like some help.
I have an attribute in the following format:
id-Structure-1.1.13.1.6.1
I need to extract the first 4 numbers (1.1.13.1)
Where it's get tricky, is that each number can have a value that may varies between 1 and 6000
so it's possible to see "id-Structure-1.5474.768.322.22.12" where I'd like to extract (1.5474.768.322)
Any help would be much appreciate
thanks
Best answer by pallegama
Hi @hugo_pspc,
Regular Expression [0-9]\\d*.\\d*.\\d*.\\d* in StringSearcher transformer works for me.
Please see the attached sample workspace.
stringsearcher
string-seracher.fmw
pallegama
Forum|alt.badge.img+8
  • Feb 22, 2018 1:07 AM UTC
Hi @hugo_pspc,
stringsearcher
string-seracher.fmw
  • Feb 22, 2018 12:49 PM UTC
It also can be done in python, A few more lines of code but does give a lot more options later
python-string.fmw
  • Feb 22, 2018 3:08 PM UTC
Works like a charm,
thank you very much
gio
Forum|alt.badge.img+15
  • Feb 22, 2018 4:29 PM UTC
is [0-9] not same as \\d ?.
Stringsearcher can also be used in advanced mode.
Use
\\W*(\\d+)\\w* or \\.*(\\d+)\\.*
and set SM (and for the all match if needed AM). SM.part(0)-SM.part(3) is what your looking for.
itay
Forum|alt.badge.img+19
  • Feb 22, 2018 9:51 PM UTC
Alternatively you can replace/erase "id-Structure-" and any points with a StringReplacer......
