How to replace part of string based on keyword? (a bulk StringReplacer?)
  • Feb 26, 2018 8:29 AM UTC
  • 11 replies
  • 220 views
Hi all,
I have a list of POI names that I'd like to abbreviate using an a Excel file that contains the keywords.
I only like to abbreviate the words found in the string that match with the keywords - not the whole string.
Basically what a StringReplacer does, but in bulk.
Thanks,
Eduard
Best answer by takashi
I found two ways.
1. Decompose, replace words if necessary, re-construct the name.
2. Use a Tcl command.
proc replace {} {
    return [string map [FME_GetAttribute "_pair"] [FME_GetAttribute "POI_NAME"]]
  • Feb 26, 2018 8:49 AM UTC
There should be a bagde of honor for everybody that submits a question here that is so well explained! :-)
  • Feb 26, 2018 9:33 AM UTC
I found two ways.
proc replace {} {
  • Feb 26, 2018 9:36 AM UTC
I found two ways.
proc replace {} {
Thanks for the fast response @takashi - I'll give it a try!
  • Feb 26, 2018 10:06 AM UTC
I found two ways.
proc replace {} {
Hi @takashi,
Looking good!
Is there a way to make these transformers not case sensitive? E.g. "Museum" is abbreviated to "Mus." which is good, but "museum" is not affected.
  • Feb 26, 2018 10:37 AM UTC
Hi @takashi,
Looking good!
In the first solution, use the @LowerCase (or @UpperCase) function in the Join On parameter setting.
  • Feb 26, 2018 11:18 AM UTC
I found two ways.
proc replace {} {
Another way. The JSONTemplater in the workflow below creates a dictionary looks like this, and the JavaScriptCaller creates the short name according to this dictionary.
   "washington" : "Wash.",
   "square" : "Sq.",
   "museum" : "Mus.",
   "street" : "St.",
   "church" : "Ch."
JSONTemplater ROOT Template Expression:
    fme:process-features("SUB")
JSONTemplater SUB Template Expression:
    fn:lower-case(fme:get-attribute("FULL")) : fme:get-attribute("ABBR")
JavaScript Code:
var dict = JSON.parse(fme_get_attribute('_dictionary'));
var src = fme_get_attribute("POI_NAME").split(' ');
var dest = []
for (var i = 0; i < src.length; i++) {
    var abbr = dict[src[i].toLowerCase()];
    dest.push(abbr ? abbr : src[i]);
fme_set_attribute('POI_SHORT_NAME', dest.join(' '));
  • Dec 5, 2019 12:34 PM UTC
   "square" : "Sq.",
   "museum" : "Mus.",
   "street" : "St.",
   "church" : "Ch."
JavaScript Code:
var dest = []
This seemed to be good solution for my problem, until I found out that JavaScriptCaller is deprecated. Is there replacement for this JavaScript code?
Forum|alt.badge.img+54
  • Dec 5, 2019 1:50 PM UTC
@bazooka You can do something with python
import fme
import fmeobjects
def insert_abbreviations(feature):
    dictionary = dict(zip(feature.getAttribute('_list{}.FULL'),feature.getAttribute('_list{}.ABBR')))
    poi = feature.getAttribute('POI_NAME')
    words = poi.split()
    words = [dictionary.get(w.upper(),w) for w in words]
    feature.setAttribute("abbreviated"," ".join(words))
*There are more efficient ways to build the dictionary than feature merging the list, but this is the simplest to demonstrate
  • Dec 9, 2019 10:28 AM UTC
import fme
import fmeobjects
    words = poi.split()
Thank you @ebygomm !
I am now 1 step closer to solution. In my case there are multiple words which needs to be changed. For example "Omena (Banaani-Appelsiini)" -> "Apple (Banana-Orange)". Now only 1st one is changed, in this case 'Omena' -> 'Apple' and the whole thing "Omena (Banaani-Appelsiini)" -> "Apple (Banaani-Appelsiini)". I don't have Python coding skills, so I don't know how to change code to solve this.
I also don't need uppercase. I tried to change
not to use uppercase, but I was not successful.
tomjerry.vl
if i have number of words like Network and Net i need to change Net as Pet but it changes Network also as Petwork like below
OriginalNeedWorking like thisNetworkNetworkPetworkNetPetPet
Note: need to replace number of Words at time like StringPairReplacer Transformer.
jovitaatsafe
Forum|alt.badge.img+11
Hi @bazooka, It looks like Takashi proposed two different solutions here. Does the first one with the TclCaller work for you? That one doesn't seem to use the JavascripCaller. If that doesn't work for you, would you be able to post a new question and link this one to it for context?
I almost overlooked your new comment thinking that this Q&A was already resolved, so posting a new one will up the visibility of your question to get more useful answers! Thanks!
