How to remove xml element if it does not consist a value?
  • Jul 25, 2018 2:10 PM UTC
  • 9 replies
  • 448 views
Hi!
I have a XML file with opening hours of corresponding days of a week.
Sometimes I don`t have the opening hour of a certain day; but I still have the title of the day in the xml file. As shown here, I have empty FRIDAY and SATURDAY elements.
What I need is to remove the OperatingTime element totally, if dayOfweek does not have any value. As it is shown here, the elements for FRIDAY and SATURDAY removed.
As I have many records like this, I believe Pyhtoncaller or InlineQuery would fix it quickly but I couldnt manage to do it. Could you help me with that?
Thanks!
jdh
Forum|alt.badge.img+41
  • Jul 25, 2018 2:38 PM UTC
You can use an xmlXQueryUpdater with a query like:
for $node in //OperatingTime
where $node =''
return (
delete node $node)
  • Jul 25, 2018 3:15 PM UTC
where $node =''
return (
delete node $node)
Agree that the XMLXQueryUpdater can be used effectively here.
Just be aware that the "where" clause above may not work as expected depending on the format of source XML. For example, if the entire document is put on a single line and there is no excess spaces between elements, all OperatingTime elements will be removed.
I think this expression would be better If there could be such a case.
where count($node/child::*) = 0
return delete node $node
Or, the "child::" can be abbreviated, as in:
where count($node/*) = 0
jdh
  • Jul 25, 2018 3:25 PM UTC
I agree that`s it`s not the best clause in the general case.
I was thinking originally of using functx:has-empty-content http://www.xqueryfunctions.com/xq/functx_has-empty-content.html
but I couldn`t get the syntax exactly right.
  • Jul 25, 2018 3:51 PM UTC
Thanks @jdh and @takashi!
So , how should I make the XMLXQueryUpdater work with xml file? Because as i am using it directly after the reader now, everything went into failed. I am attaching an example.xml similar to my original file.
  • Jul 25, 2018 3:55 PM UTC
I'm afraid that FME doesn't bundle the Functx Function Library...
jdh
  • Jul 25, 2018 3:57 PM UTC
That would explain why I couldn't get it to work. I just figured it was my lack of skill in xquery.
jdh
  • Jul 25, 2018 4:14 PM UTC
Don't read it in as a CSV.
You can use the XML reader, text file (whole file at once), or use a creator and in the XMLXQueryUpdater set the XML source to the file instead of an attribute containing the XML.
friesewoudloper
Participant
hoursoperationlist.xml
strip-hoursoperationlist.fmw
I think XSLTProcessor with a simple stylesheet does the job.
friesewoudloper
Participant
strip-hoursoperationlist.fmwhoursoperationlist.xml
The links in my answer are broken, so I'll give it another try. I also include screenshots, just in case ;-)
