How to remove square brackets in a column?
  • Nov 14, 2018 3:03 PM UTC
  • 10 replies
  • 437 views
Hi everyone,
I looked up at some forum posts, I saw people excluding the content within squarebrackets with square brackets itself or deleting some funny characters, but I couldn't really find something which suit my situation or I just didn't understand the forum posts quite well.
The case is, I have got a column with strings such as "[]" or "[Park5, Park4]" and ideally I would like to remove the square brackets. I tried it with the stringreplacer with the regualr expression, however that didn't work, it has to be said that I am not that familiar with regular expression, so the way how I formulated it, might be wrong. In my case, I want to keep the content within the square brackets, while only deleting the square brackets itself.
Thank very much in advance!
  • Nov 14, 2018 3:12 PM UTC
Try text to replace
Replacement text
\1
Forum|alt.badge.img+54
  • Nov 14, 2018 3:44 PM UTC
You could also use a string pair replacer, with the following replacement pairs
Try text to replace
Replacement text
\1
@david_r   thank you very much for the formulation of the regular expression,
however I have another issue. It appeared afterwards that the comma in the [Park5, Park4]"  for example led to some problems when importing into another software, therefore, the comma preferably should also be deleted. I know vaguely that the ^ character is involved, however I have not really a clue how to formalate that
  • Nov 14, 2018 3:47 PM UTC
This is a good one. Added bonus: easy to modify to get rid of the comma as well.
  • Nov 14, 2018 3:48 PM UTC
To replace the comma too, use [ "" ] "" , ""
Unfortunately the stringpairreplacer is not very legible when replacing single characters like this. You can vote for my improvement idea here https://knowledge.safe.com/idea/81295/stringpairreplacer-interface-improvements.html
  • Nov 14, 2018 4:43 PM UTC
@egomm wow that is a nice alternative, Is it possible to include symbols? I would like to add parentheses around a number for example, thus Park5 will become Park(5) or should I use the StringReplacer for that?
  • Nov 14, 2018 4:49 PM UTC
I suspect you'll need the StringSearcher for that one, as the StringPairReplacer is about replacing known characters. You can try this:
Text to replace:
(\d+)
Replacement text:
(\1)
  • Nov 14, 2018 5:16 PM UTC
Text to replace:
(\d+)
Replacement text:
(\1)
@ david_r , for some reason after doing all the steps mentioned before
1) deleting square brackets in stringpairreplacer
2) deleting comma's in stringpairreplacer
3) and surrounding parentheses around the numbers in stringreplacer
I get the following output in the other software when I importing the column,
The square brackets in this case, is due to the fact that I am reading the column in the software as lists, therefore the squarebrackets. If I didn't remove the squarebrackets beforehand in FME, there would have been list in another list.
However as you can see, instead of 'Park(5)','Park(4)' I get thus the thing above in the picture. So I was wondering how I could prevent the seperate entities as in the above picture
  • Nov 14, 2018 5:57 PM UTC
What format are you writing to? It sounds like something that's being inserted on writing and may be controlled by a parameter in the writer. I presume if you hook up an inspector to the stringreplacer and look at the attributes they don't have the quote marks?
  • Nov 14, 2018 7:43 PM UTC
@egomm Yes when I look at inspector, there areindeed no quotation marks. When I delete the square brackets and the comma, then this problem doesn't occure. It's only after including the parentheses, that this does occur. In case when it has to do with a parameter in the writer, do you have by any chance an idea about which parameter it might be the case?
