How to remove extra coordinates?
  • Sep 14, 2017 8:40 PM UTC
  • 114 views
Hi! I have one problem with coordinates of my objects. For example, I created a simple cube in Revit and exported to IFC file. After that I opened file in FME Data Inspector and I have 24 vertices or coordinates instead of 8 which I think I should have. So they are tripled. Therefore, when I calculate volume it is three times bigger. On the other hand, area calculator works fine. Is there any possibility to remove coordinates and leave only one for each vertex or maybe something else is a problem?
Best answer by daveatsafe
Hi @oliverakaranovi,
The coordinate count is based on a simplified representation of the cube, where it has six faces, each of which has 4 vertices, so the coordinate count is 24.
However, the volume is being calculated incorrectly, possibly due an issue in the geometry. If you run the feature through a GeometryValidator with the Degenerate geometry test, the output feature will have its geometry calculated correctly.
I have created a problem report for our development team to look into this issue.
Here is the file which I am using cube.zip
daveatsafe
Forum|alt.badge.img+24
  • Sep 14, 2017 9:41 PM UTC
Thank you for your help. I will try Degenerate geometry test.
Hi again! I used Degenerate geometry test and then calculated volume and it is correct. So it is some issue in the geometry, like you said. My question now is what can be a possible problem? Is it possible that I created something wrong in Revit or exported IFC incorrectly? But it is just a simple cube that I created and I exported to IFC with default settings.
