Schema is coming from the schema port of the feature reader and data is coming from the generic port. If I change the structure of the table connecting transformers to the schema port those changes are not reflected in the output data that is coming out of generic port. Any help is appreciated for more information please see attached image called "sample". Thanks in advance.
How to remove and rename attributes coming from dynamic feature reader?
