How to read DGN files and work with them in high performance ?
  • January 26, 2023
  • 8 replies
  • 177 views
gogopotter90
Forum|alt.badge.img+13
Hello ,
i have around 10 GB DGN files and it takes time to load in FME and and it seems slowly to work with them .
i would like to know , if there is best method to work with DGN files ?
Or should I convert them to other format ,if it will be besser then I work with them in new format ?
FME 2021
Thanks in Advance
Forum|alt.badge.img+50
10 Gb of any file format is going to take time to process 😅
If you can tell us a bit more about what you're trying to do we may be able to give you more detailed advice.
gogopotter90
  • January 27, 2023
I have my polygons as DGN files , size of folder that contains DGN files around 10 Gb. I would like to find a way to work with them quickly .
i have lots of points as oracle DB and I want to use point on area to find which point locates inside the polygons (DGN files ).
this is my target ,thanks for help .
You could try loading the polygons in Oracle as well and make sure that table is spatially indexed. It's hard to say what the performance gain (if any) would be.
gogopotter90
  • January 27, 2023
Sry for asking again ,could I load DGN file where fme_feature_type = value or fme_feature_type = another value
so I do not need to load all data in DGN files .is there a method ?
  • January 27, 2023
I can only confirm that reading DGN files can, in some cases, be relatively slow. I can't say if this is due to the complexity of the format, the libraries FME use for reading them, or both.
If your DGN files are relatively static but you need to read them multiple times, a solution could be to transform then once to the FFS format and then work with those files instead. That should be much faster.
gogopotter90
  • January 27, 2023
Thanks ,I will convert them .
gogopotter90
  • January 27, 2023
@david_r​
while I am reading DGN file,could I select specific values from tables ? does it possible ?
i want to use condition ,when FME featur type =value or another value ,read only them and ignore the rest
  • January 28, 2023
Unfortunately dgn files do not behave like a database. I believe that FME will end up reading the entire dgn file even if you set a feature type filter. But I'm not quite sure. You'll have to try it out, I think.
