How to read a GLTF file ?
  • Apr 23, 2019 9:42 AM UTC
  • 225 views
https://knowledge.safe.com/content/idea/24218/gltf-readerwriter.html
@daleatsafe said "A glTF writer is under development right now and will soon be in FME 2017 beta."
The FME 2018 does not have this transformer.
Forum|alt.badge.img+63
There is a glTF writer in FME 2019 actually, but that won't help you.
As it's a JSON-based format you should be able to use the standard JSON reader and then work your way through it, e.g. with the JSONFragmenter or JSONFlattener but that might be a lot of work. You can also upvote that idea, hoping that Safe will pick it up.
