How to read a Custom unknown type of XML?
  • September 5, 2014
  • 10 views
paalped
Forum|alt.badge.img+5
Hello,
I want to read an XML schema, which i don't know what kind of XML it is. It could be, XML,GML,LandXML,RSS. I've tried many readers but all fails. All readers I have tried, gives me the messages that the xf-mapping could not determine the xml schema.
I've tried findeing out how to create a new xfmap file, but I could not quite get the hang of it.
So I'm wondering if any XML-Guru's  out there can help me?
I Want to be able to read this XML feed:
http://www.vegvesen.no/trafikk/xml/search.xml?searchFocus.counties=2
How do I begin?
  • September 5, 2014
Heisann,
rather than using the relatively complex xfMaps, I recommend you look into the so-called feature paths functionality introduced in FME 2013. Here is a good intro: http://fmepedia.safe.com/articles/How_To/Reading-XML
Lykke til med trafikkmeldingene :-)
David
fmelizard
Forum|alt.badge.img+17
  • September 5, 2014
Just use a text reader, point it to the url and set the parameter to read all at once to yes.
After that you can use the XMLFragmenter (elemnts to match : messge) to transform the xml fragments into attributes.
Hope this helps,
Itay
paalped
  • September 5, 2014
Don't mind i Finally figured it out. It was really easy actually. just by typing each word I wanted to match in the list of matched object. In the general xml-reader.
