Completely suppress logging
  • Mar 17, 2025 2:33 PM UTC
  • 6 replies
  • 210 views
itay
Forum|alt.badge.img+19
Hi There,
I was wondering if anybody knows of a way to completely or partially suppress the logging in a workspace? (even if it is a hacky method)
I am aware of the settings in the options menu but unfortunatly they just don’t do the job necessary.
Cheers,
Itay
Best answer by david_r
Try the following in the Python startup script:
import fmeobjects
fmeobjects.FMELogFile().silent(True)
Testing with FME 2025.0 I only get the lines up until the startup script is executed, then only a single line at the end stating the the translation was successful.
Documentation: https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_log/fmeobjects.FMELogFile.silent.html
  • Mar 17, 2025 3:30 PM UTC
import fmeobjects
itay
  • Mar 17, 2025 3:37 PM UTC
Hi ​@david_r,
Thanks for the fast responce, this works in Form like a charm now….Is it possible to implement it in a linked transformer? 😉 (no startup script option there)
Cheers,
Itay
  • Mar 17, 2025 3:40 PM UTC
I guess you could put it in a PythonCaller, just be aware that it’s a global setting that will influence the entire workspace execution, and probably not just the linked transformer (not tested).
You can set .silent(False) to re-activate logging.
itay
  • Mar 17, 2025 6:42 PM UTC
HI ​@david_r,
Unfortunately this does not work since the workspace is already initiated and therefore cannot be set to ‘silence’ the logfile. I don’t know if there is a way to do this at all, I will settled for encrypting the logfile but then again this might also prove to be beyond the current capabilities.
Itay
  • Mar 18, 2025 8:06 AM UTC
That sounds unexpected. My understanding is that you should be able to silence and un-silence the log at any point during the translation.
itay
  • Mar 18, 2025 8:52 AM UTC
Hi ​@david_r,
I would gladly be proven wrong :) this would be the best solution for me.
