How to put string literal in sql statement
  • Jan 31, 2019 2:01 PM UTC
  • 5 replies
  • 1258 views
so I have an update SQL query that the sql executor transformer executes. It looks like UPDATE *TABLE_NAME* SET COLUMN_NAME = @VALUE(ATTRIBUTE_1) WHERE OTHER_COLUMN_NAME = '@VALUE(ATTRIBUTE_2)'
The first attribute is always a number, but the second one is a string so I have to put quotes in. But, the string can contain quotes itself, which causes the query to fail for those cases. If I put double quotes around it I get a SQL error: it thinks I'm setting it equal to the value of another column in my database table instead of a FME attribute.
How do I put the whole string value of attribute 2 in my where clause, quotes and all?
Thanks!
francis_m
Forum|alt.badge.img+9
  • Jan 31, 2019 2:10 PM UTC
To update in SQL your query must be like :
UPDATE <tbl_nm>
SET <att_nm1> = ( your attribute name)', <att_nm2> = ( your attribute name)'
FROM <tbl_nm>
WHERE<att_nm3> = '( your attribute name)'
If it is an integer, you dont need the quotes ('). But if your update or where statement is a string, the @Value() must be between quotes.
Then, if your string contains quotes, you must double them ...
example : 'It's cold outside' become 'It'' cold outside'
It look like in your string you dont have the FROM <tbl_nm> even if you specified it in the UPDATE statement.
Good luck!
  • Jan 31, 2019 2:12 PM UTC
If it's Oracle you can specify an alternative quote character to avoid collisions with quotes in your attribute values. Here's an example where the quote character is set to #:
 ... WHERE OTHER_COLUMN_NAME = q'#@VALUE(ATTRIBUTE_2)#'
It's documented here: https://livesql.oracle.com/apex/livesql/file/content_CIREYU9EA54EOKQ7LAMZKRF6P.html
  • Jan 31, 2019 2:31 PM UTC
UPDATE <tbl_nm>
FROM <tbl_nm>
Good luck!
Which SQL variant is this? The regular SQL syntax for updating table contents usually does not include the FROM clause:
UPDATE table_name
SET column1 = value1, column2 = value2...., columnN = valueN
WHERE condition;
  • Feb 4, 2019 11:46 AM UTC
Thanks, this worked!
nielsgerrits
Forum|alt.badge.img+67
A StringConcatenator can help with creating SQL statements as well.
