Hi All,
I am trying to merge several raster tiles into a single one using RasterMosaicker. Unfortunately, in the output raster you are able to see horizontal and vertical white lines as well as a horizontal black line at the bottom.
Please note these are not present after georeferencing the tiles and is only after the used of the RasterMosaicker transformer that they appears.
Is there a transformer I need to use prior this or are the parameters within the RasterMosaicker the ones need altering?
Any ideas welcome!
Thanks,
Ana
