How to populate an attribute using the results of an SQL query?
  • August 19, 2021
  • 359 views
redbul
I've created a new Output Attribute in AttributeManager and I want to populate this based on the results of a (rather lengthy) SQL query.
However, the SQL will be looking at attribute values from the reader and not a database, which I think rules out SQLCreator and SQLExecutor.
Does anybody have any suggestions as to how I might manage this?
Forum|alt.badge.img+62
The InlineQuerier is probably what you need. It'll build an in-memory database from the input features upon which you can run SQL queries.
redbul
  • August 19, 2021
Thanks, that looks like it might do the job! Just got to work out how to use it now!! 😉
jkr_wrk
Forum|alt.badge.img+36
  • August 19, 2021
I have a workbench that does something like this with the SQLExecutor:
SELECT "id","start_date" FROM "activities" WHERE "ORDER BY "id" DESC LIMIT 1 OFFSET @Value(Offset)
If the Offset Attribute is 10 then this query selects the 10th last inserted record. I use this to query an API to get all records that are after the start_date of that record. This way I can check the last records for changes and get all the new records. Within the SQLExecutor you then Expose the id and start_date Attributes.
The workbench also has a lot of DatabaseJoiners. Those test if records exist without downloading all the data in those records. If Joined do A else do B.
The InlineQuerier creates a new database from the Features you put in (that probably are already in a database) and then you can preform SQLite queries on that database to get new features out. This could be a fast way to process your features, but mainly if A, the features are not from a database, or B, the database has a very slow CPU/Memory comparing to the CPU/Memory of FME.
