How to pass through a lot of files with python defies error message from fme workspace?
  • June 8, 2015
  • 6 replies
  • 79 views
Hi everyone
I have to create shapefiles from SWISS Interlis data for over 1000 SWISS Interlis files.
How can I pass through all SWISS Interlis files with help of Python code even if I get from some SWISS Interlis files error message like this:
Traceback (most recent call last):
  File "C:\\temp\\AV\\FMEWorkspaceAusfuehren.py", line 73, in <module>
    runner.runWithParameters(workspace, parameters)
FMEException: FMEException: 1: Failure running workspace 'C:\\temp\\PyTEST\\ITF2Shape.fmw'
My python code see below :
import os
import os.path
import sys
sys.path.append("C:\\\\Program Files (x86)\\\\FME\\\\fmeobjects\\\\python27")
import fmeobjects
# Source path
source = 'C:\\\\temp\\\\PyTEST'
# Change to source path
os.chdir(source)
print "source = " + source
# Init FMEWorkspaceRunner Class
runner = fmeobjects.FMEWorkspaceRunner()
# FME workspace path
workspace = 'C:\\\\temp\\\\PyTEST\\\\ITF2Shape.fmw'
# List SWISS Interlis files
ListITF = []
for daten in os.listdir(os.getcwd()):
     if daten.endswith('.itf') or daten.endswith('.ITF'):
          ListITF.append(daten)
          print "ITF file " + daten + " listed."
print "ITF-Files listed."
# FME Workspace prepare
for itfOrdner in ListITF:
     #SWISS Interlis basename
     count = 0
     newSourceDataset = ListITF[count]
     newDestDataset = os.path.splitext(os.path.basename(itfOrdner))[0]
     # FME workspace parameters
     parameters = {}
     parameters['SourceDataset_ch.ehi.fme.Main'] = source + '\\\\' + str(newSourceDataset)
     parameters['DestDataset_SHAPE'] = source + '\\\\' + str(newDestDataset)
     print "SourceParameters: " + parameters['SourceDataset_ch.ehi.fme.Main']
     print "DestDataset: " + parameters['DestDataset_SHAPE']
     count = count + 1
     # Start FME Workspace
     print "Workspace started."
     print "Workspace finished."
# FME process rid
runner = None
Thanks Zoran
  • June 8, 2015
Hi
what does the file "C:\\temp\\PyTEST\\ITF2Shape.log" say?
David
  • June 8, 2015
If you just need to ignore errors from the runWithParameters command, try the following Python idiom:
try:
except:
    pass
David
  • June 8, 2015
Hi David
The logfile says same as python error message:
2015-06-08 13:54:06|  31.4|  0.0|STATS |DM01AVCH24D.TSEinteilung.Toleranzstufe (DM01AVCH24D.TSEinteilung.Tole        2
2015-06-08 13:54:06|  31.4|  0.0|STATS |DM01AVCH24D.TSEinteilung.ToleranzstufePos (DM01AVCH24D.TSEinteilung.T        2
2015-06-08 13:54:06|  31.4|  0.0|STATS |DM01AVCH24D.TSEinteilung.Toleranzstufe_Geometrie_LT (DM01AVCH24D.TSEi        3
2015-06-08 13:54:06|  31.4|  0.0|STATS |DM01AVCH24D.TSEinteilung.Toleranzstufe_MT (DM01AVCH24D.TSEinteilung.T        2
2015-06-08 13:54:06|  31.4|  0.0|STATS |==============================================================================
2015-06-08 13:54:06|  31.4|  0.0|STATS |Total Features Written                                                   85638
2015-06-08 13:54:06|  31.4|  0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2015-06-08 13:54:06|  31.4|  0.0|ERROR |java.lang.Exception: INTERLIS 2 reader failed
2015-06-08 13:54:06|  31.4|  0.0|INFORM|FME Session Duration: 39.7 seconds. (CPU: 28.5s user, 2.5s system)
2015-06-08 13:54:06|  31.4|  0.0|INFORM|END - ProcessID: 6036, peak process memory usage: 144220 kB, current process memory usage: 138340 kB
Zoran
  • June 8, 2015
Hi David
I tried already dio options with
try:
except:
   pass
The problem is that after error message (run FME workspace) the pythone code shalls ignore the FME workspace error message and  process the next SWISS Interlis file in the list (ListITF) and not jump to the except: code block.
Zoran
  • June 8, 2015
That's going to be difficult, if not impossible.
Is it at all possible for you to call the workspace once per ITF file?
David
  • June 9, 2015
Hi David
Thank you very much for your support.
I solved the problem!!!!!!
First I defined a function to run the FME workspace.
The function guaranteed the processing of all files also if the FME run fail.
def start_workspace(works,param):
    failed = False
    result = None
    try:
        result = runner.runWithParameters(works, param)
    except:
        failed = True
    return failed, result
And then lower in my python code I start FME Workspace:
     failed = start_workspace(workspace,parameters)
     result = start_workspace(workspace,parameters)
     if failed:
        continue
Complete python code see below:
import os
import os.path
import sys
import fmeobjects
# Source path
os.chdir(source)
ListITF = []
# Function to run FME workspace
# The function guaranteed the processing of all files also if the FME run fail
    failed = False
    result = None
    try:
    except:
        failed = True
# Init counter
count = 0
     parameters = {}
     count = count + 1
     if failed:
        continue
# FME process rid
runner = None
Zoran
