How to normalize house numbers using Regular Expression?
  • May 4, 2018 5:58 AM UTC
  • 97 views
Hello FME masters,
I have a set of housenumbers I'd like to update. I'm trying RegEx but not getting the result I want.
What it boils down to:
HaveWant1-A1A22-2422
First example: I'd like to clean out the dashes but keep the letter following the dash.
Second example: Clean out the dash and any digits following it.
How can I do this in the StringReplacer?
Thanks,
Ed
Best answer by denizturan1985
Hello Ed,
You can use the expression below and replace with nothing.
(?<=\d)\-\d*
denizturan1985
Participant
  • Participant
  • May 4, 2018 7:27 AM UTC
Hello Ed,
(?<=\d)\-\d*
  • May 4, 2018 7:49 AM UTC
Hello Ed,
(?<=\d)\-\d*
Hi @denizturan1985,
Thanks! - that tHERE did the trick nicely. ;-)
Cheers,
Ed
