How to name an output json file with the value of an attribute?
  • Mar 31, 2023 10:53 AM UTC
  • 111 views
claireco
Good morning
I want to generate a json file that accompanies a photograph and I want the name of the json file to be the name of the photo which is contained in a 'Photo' attribute
I also want as many json files named with the name of the photo as there are photos in my source directory.
I tested in the json output to put the Photo attribute in the entity name but it doesn't work.
ThanksCapture d’écran 2023-03-31 125203
Forum|alt.badge.img+63
There's a Fanout option on the writer itself, in the Navigator, that can be used to make the filename dynamic based on an attribute. Set Fanout Dataset to Yes and then in the Fanout expression you can pick the attribute.
claireco
  • Mar 31, 2023 12:23 PM UTC
Thank you, it works
How can I add the extension *.json at the end of the name of the json file ?
Thank you, it works
Add .json to the end of that Fanout expression 😄
claireco
  • Mar 31, 2023 12:33 PM UTC
Thank you for your prompt response, it works
