How to make the MapnikRasteriser create one output per input feature
  • Jan 28, 2019 10:46 AM UTC
  • 46 views
Hello.
I'm using a mapnik rasterizer to overlay a couple of vector datasets on a set of rasters. I have three input, one raster and two vector. When I run it it produced one output including the three input rasters on top of eachother. How can I set it up to run separately for each input raster?
Forum|alt.badge.img+63
You can use the Group By function to do that, for every unique value of the attribute(s) selected there it will make a new raster. You'll have to make sure your vectors and the raster they should overlay have that attribute in common.
