How to make a spatial join?
  • Jun 29, 2022 12:58 PM UTC
  • 168 views
I have two geodatabase.
I used "AreaOnAreaOverLayer" to have the intersections of features for the one of the geodatabase and then, for the second geodatabase. It creates for both, a field named “Overlaps”.
It works correctly.
After that, I wanted to join the two geodatabases
The two geodatabase overlap but they haven’t the same name so I can’t use « feature joiner » because I haven’t a common field.
With the transformer “clipper” I haven’t all fields  (It misses the field “overlaps” of one of the geodatabase)
With “AreaOnAreaOverLayer”, “SpatialRelator”, “SpatialFilter” and NeighboorPair” one of the field "overlap" is null
That’s why I want a transformer to make a spatial join and not a attribute join with all fields of two geodatabase.
Thank you !
Best answer by geomancer
The AreaOnAreaOverlayer has an option to merge all incoming attributes on the resulting features. Is that what you are looking for?
AreaOnAreaOverlayer_Merge_Incoming_Attributes
geomancer
Forum|alt.badge.img+71
  • Jun 29, 2022 1:35 PM UTC
It worked ! Thank you very much!
