How to join to lines that don't share a start/end point?
  • Feb 10, 2023 5:01 AM UTC
  • 290 views
james_c_452
Forum|alt.badge.img+10
I have two lines I would line to join together. However they do not intersect with each other so I can't use the line combiner. The lines are 3D and I want to preserve the dimensions so a neighbour finder might not work because that is 2D
They are lines along the centre of a rail line but there is a small gap (see picture). I would like to join it so that it forms one line. The direction of the lines is the same.
If anyone has any ideas how I could do this I would be very appreciative
Thanks
nielsgerrits
Forum|alt.badge.img+67
Probably multiple ways to do this, but one way is to do fix the connectionlines in 2D first, then fix the 3D part. Sample workspace attached.
3DNeighborFinder
james_c_452
  • Feb 15, 2023 10:49 PM UTC
3DNeighborFinder
Thanks for the reply @nielsgerrits​ . I ended up just using the Snapper which appears to have worked. Don't know how I didn't think of that earlier. Your workspace will be handy for other things I do though! I do have a way to do 3D snapping myself. But that only works on points (I convert the base or candidate to a pointcloud and run the maths on pointcloud components)
