How to insert XML fragments stored in an attribute into XML document using XMLUpdater
  • Feb 14, 2022 1:53 AM UTC
  • 206 views
dms2
Forum|alt.badge.img+11
I have this xml fragment in an attribute called distr_formats and need to insert it in a specified location of an xml document (stored in another attribute):
<gmd:distributionFormat>
    <gmd:MD_Format>
        <gmd:name>
            <gco:CharacterString>DWG</gco:CharacterString>
        </gmd:name>
        <gmd:version>
            <gco:CharacterString>r2013</gco:CharacterString>
        </gmd:version>
        <gmd:fileDecompressionTechnique>
            <gco:CharacterString>ZIP</gco:CharacterString>
        </gmd:fileDecompressionTechnique>
    </gmd:MD_Format>
</gmd:distributionFormat>
    <gmd:MD_Format>
        <gmd:name>
            <gco:CharacterString>SHP</gco:CharacterString>
        </gmd:name>
        <gmd:version>
            <gco:CharacterString>-</gco:CharacterString>
        </gmd:version>
    </gmd:MD_Format>
These are the parameters in my XMLUpdater transformer:
XMLUpdaterI'm getting this error and I'm not sure what I'm doing wrong:
 invalid expression: syntax error, unexpected ">"
Any idea?
Thanks!
Best answer by takashi
Another thought. Just setting this XQuery expression in the Value column could also be possible, instead of transforming the input "distr_formats" string with the method I mentioned above.
This expression returns a sequence consisting of the two <gmd:distributionFormat> elements.
for $x in <temp>@Value(distr_formats)</temp>/*
return $x
  • Feb 14, 2022 11:17 AM UTC
Hi @dms2​ , the reason for the error is that the value of distr_formats is NOT a single XML fragment, it's just a concatenated string of two <gmd:distributionFormat> fragments.
A possible workaround is to transform the value to an XQuery sequence - comma-separated elements quoted by round brackets - before entering it to the XMLUpdater.
<gmd:distributionFormat><gmd:MD_Format><gmd:name><gco:CharacterString>DWG</gco:CharacterString></gmd:name><gmd:version><gco:CharacterString>r2013</gco:CharacterString></gmd:version><gmd:fileDecompressionTechnique><gco:CharacterString>ZIP</gco:CharacterString></gmd:fileDecompressionTechnique></gmd:MD_Format>
<gmd:distributionFormat><gmd:MD_Format><gmd:name><gco:CharacterString>SHP</gco:CharacterString></gmd:name><gmd:version><gco:CharacterString>-</gco:CharacterString></gmd:version><gmd:fileDecompressionTechnique><gco:CharacterString>ZIP</gco:CharacterString></gmd:fileDecompressionTechnique></gmd:MD_Format>
How to? For example,
StringReplacer
  • Attributes: distr_formats
  • Mode: Replace Regular Expression
  • Case Sensitive: No
  • Text To Replace: (</gmd:distributionFormat>)\s*(<gmd:distributionFormat>)
  • Replacement Text: \1,\2
StringConcatenator
  •  Expression Results: Overwrite Existing Attributes
  • Attributes To Overwrite: distr_formats
  • Concatenation: (@CurrentAttribute())
  • Feb 14, 2022 11:36 AM UTC
return $x
dms2
  • Feb 14, 2022 2:24 PM UTC
Thank you so much @Takashi Iijima​ .
Both options are good for me but the Xquery expression saves me from adding extra transformers to the flow.
Learning XQuery still is a pending topic I've had for years. I'd like to dig into it some day. I must say though that it's you who I must thank for the little I know of it.
