How to insert Annotations along with the dimension/leader lines into an Annotation Class in a FGDB?
  • May 19, 2017 4:55 PM UTC
  • 56 views
We are observing issues while trying to insert the Annotation Text along with the Leader/Dimension lines, into an Annotation Class in a FGDB. The Annotation Text and the Leader/Dimension lines are separate components in source FFS files. The annotations are getting inserted properly but linear features getting inserted with all Null attributes and getting represented as an image in ArcMap. Please suggest.
  • Mar 7, 2018 10:37 PM UTC
Conversion of dimensions and leader lines, either to or from CAD from a file geodatabase is not supported. Very sorry this functionality is not available.
