How to increase performance Directory and File Pathnames to read the name of all excel files in folder and subfolders
spiderman
Forum|alt.badge.img+7
i would like to read the name of all excel files in folder and subfolders but i found it takes long time , any ideas please .
drc43
Forum|alt.badge.img+11
  • August 9, 2021
Are you using a Path Filter to read in only excel files? (.xls, .xlsx)
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/path/Set_Path_Filter.htm
hkingsbury
Forum|alt.badge.img+55
  • August 9, 2021
A lot of things could effect the speed of this. As @drc43​ mentioned, are you filtering by excel files? Also how deep are you searching (with folder hierarchy), how many files/folders are there to check, is the data on a hdd or ssd, is it local or remote, if its remote what's your network connection like?
I've run similar processes before (looking for .xlsx) over a remote network drive that had well in excess of 20tb of data. It took a couple of days to complete.
spiderman
  • August 9, 2021
i have chosen for path filter *.xlsx but if i want to read also .xls in case i hae old version of excel
how will be looks like ,i have tried in path filter *.xls|*.xlsx but i got nothing or i have tried .xls, .xlsx .
i got only output when i use *.xlsx
what should i write in path filter ?
spiderman
  • August 9, 2021
the data on hdd but remotely .
i have only to use path filter nothing more could i do to increase the performance because i did already the path filter but it still slow and data around 5 giga byte
hkingsbury
  • August 9, 2021
Whats your definition of slow?
If its on a spinning remote disk (hdd) then I would expect it to have poor performance. What is speed like when browsing the disk using Windows Explorer? roughly how many files are there that make up the 5gb?
@spiderman​ The documentation that @drc43​ referenced probably gives the hint you need under the Path Filter section. Using the Path Filter instead of c:/temp/**/*.xlsx makes quite a difference
spiderman
  • August 9, 2021
how could i include also xls extension not only xlsx ?
  • August 10, 2021
As mentioned, a remote disk is not ideal for performance. Additionally, make sure that you haven't activated "Retrieve file properties" on the reader, that can add quite a lot of time, especially for remote partitions with large amounts for files.
jkr_wrk
Forum|alt.badge.img+29
  • August 10, 2021
According to the documentation you need to use: {*.xls,*.xlsx} or *.xls*
http://docs.safe.com/fme/2019.1/html/FME_Desktop_Documentation/FME_ReadersWriters/path/PATH_reader.htm
You can view the documentation by clicking Help in the Parameters dialog.
Or by clicking on: See Directory and File Pathnames Reader Parameters for additional information and then on Path Filter.
