How to identify short lines that partly duplicates longer line
  • Oct 31, 2019 11:36 AM UTC
  • 7 replies
  • 201 views
isis
Participant
Forum|alt.badge.img+3
I have one feature layer with lines that are not topologically cleaned. There are many lines that are partly duplicated with shorter lines. Except FID, other attributes are the same.
Any suggestions how to identify duplicate polylines (short lines)? LineOnLineOverlayer dont work for me.
Forum|alt.badge.img+63
The LineOnLineOverlayer will split up lines where they overlap, try the SpatialFilter (or SpatialRelator) instead.
Forum|alt.badge.img+54
  • Oct 31, 2019 11:58 AM UTC
After the LineOnLineOverlayer you will want to test for lines wiht overlaps greater than 1, this will return the overlapping segments. If you need to know the IDs of the feature you can build a list
isis
Participant
  • Participant
  • Nov 1, 2019 1:27 PM UTC
How to test lines with overlaps greather than 1 ?
isis
Participant
  • Participant
  • Nov 1, 2019 1:28 PM UTC
SpatialFilter and SpatialRelator doesnt work too, because all lines are in the same shapefile.
  • Nov 1, 2019 2:09 PM UTC
The _overlaps attribute is automatically generated in the line on line overlayer, then you just need a tester
  • Nov 1, 2019 2:12 PM UTC
In the same shapefile shouldn't be a problem in itself, you can send the shapefile to both requestor and supplier port, and as long as each feature has a unique attribute you can use this in the attributes must differ paramet to avoid each feature comparing against itself. I'd avoid it for this scenario however, as there is no tolerance within this transformer so might not give the output you're looking for.
isis
Participant
  • Participant
  • Nov 1, 2019 2:22 PM UTC
Thank You! I will try this.
