How to get unique code depend from two columns?
  • Jul 12, 2019 2:16 PM UTC
  • 31 views
Hi together
The initial situation is as follow:
The relation between column TR and column LTG is 1:n.
Every value in the column LTG need to get a unique code independent from TR.
The CODE also has to be unique per TR.
TR
LTG
CODE
A
1
A
2
B
3
B
1
C
1
C
3
I would like to get follow result (the code has to be unique per LTG and order is not importent):
TR
LTG
CODE
A
1
2
A
2
1
B
3
1
B
1
2
C
1
2
C
3
1
@zoran68 I think you can use the Counter with a Counter Name of "TR". This gives you a separate count Domain for each value of TR, independent of LTG.
This would b the result:
