How to get token by using httpcaller?
  • Feb 1, 2023 6:49 AM UTC
  • 302 views
limo
Forum|alt.badge.img+8
There are some postings on this but it does not work for me yet:
I am trying to contact an external API via HTTP POST to get a token back.
It already works with python. But we wanna integrate the workflow in fme server and Iam sure it will work with fme.
Python script:
# Parameter_____
base_url = 'https://apieco.eco-counter-tools.com'
api_key = 'XXX'  # Base64 encoded secrets
# Tokenabruf
def get_token(url, api_key):
    header = {
        'Content-Type':'application/x-www-form-urlencoded',
        'Authorization': 'Basic ' + api_key
    r = requests.post(url + "/token", headers= header, data={'grant_type': 'client_credentials'})
    answer = json.loads(r.text)
    token  = answer['access_token']
    return token
HTTPCaller:
Erorr Message:
HTTP/1.1 415 Unsupported Media Type
Which mime type should I use for the grant_type: client_credentials?
Best answer by limo
Ah I got it:
I have to define "grant_type= client_credentials" inside the parameter for query string
limo
  • Feb 1, 2023 7:17 AM UTC
Ah I got it:
