How to get log generated in custom transformer ?
  • Aug 11, 2021 11:53 AM UTC
  • 172 views
I have a workbench which has a complex custom transformer added in which a python caller is present. I wanted to check what is happening in that python caller so I used some print statements. But I cannot find those print statements in logs that is being generated. How to get the log of a custom transformer in FME Desktop 2019.
Best answer by david_r
Print statements will appear in the on-screen log window, but will not necessarily be logged in the exact same order as the transformer messages, and may only appear on-screen and not in the log file.
The best way to log messages is to use the FMELogFile object in the fmeobjects API. Example:
import fmeobjects
def my_function(feature):
    # Do something ...
    # Sends a message to the FME log file and console window.
    # Severity must be one of FME_INFORM, FME_WARN, FME_ERROR,
    # FME_FATAL, FME_STATISTIC, or FME_STATUSREPORT.
    message = 'This message will appear both on screen and in the log file'
    severity = fmeobjects.FME_INFORM
    fmeobjects.FMELogFile().logMessageString(message, severity)
    # Do something else here...
  • Aug 11, 2021 12:11 PM UTC
import fmeobjects
    # Do something ...
  • Aug 11, 2021 12:49 PM UTC
import fmeobjects
    # Do something ...
Got it.. Thanks
