How to get coordinate system detail from Source Data .
  • Jun 15, 2018 6:20 PM UTC
  • 96 views
rajibtechlabs
Like
Projection
Standard parallel (s)
Longitude of origin
Unit
False easting \\ northing
Best answer by erik_jan
The name of the coordinate system in the data can be retrieved using the CoordinateSystemExtractor transformer.
Using that name, go to the menu Tools > Browse Coordinate Systems.
Using the properties button you can view the settings for the coordinate system of your choice:
erik_jan
Forum|alt.badge.img+26
  • Jun 15, 2018 6:57 PM UTC
  • Jun 17, 2018 7:52 AM UTC
Additionally, you can use the CoordinateSystemDescriptionConverter to convert an FME coordinate system identifier which is extracted by the CoordinateSystemExtractor to its detailed description with OGC WKT or Esri WKT format.
taojunabc
Participant
  • Participant
  • Jun 18, 2018 1:14 AM UTC
I often use the following method, which is similar to the @erik_jan's method, but it may be faster.
Set a breakpoint, click on the coordinate system text in the Feature Inspector, and the coordinate information window will be displayed.
Of course, you can also use the FME Data Inspector to directly view the data, and then use the above method.
But I personally prefer to use breakpoints because it is displayed when reading the first feature. This method saves time if the data volume is large.
