How to get/calculate reminder and rounding numbers?
  • Sep 27, 2018 3:15 PM UTC
  • 305 views
bobo
Forum|alt.badge.img+3
Hi, everyone, I'd like to do some math calculations in FME, just like Field Calculator in ArcGIS. I'm trying to calculate reminder and rounding numbers, but I'm not sure which math operator to use. Here're some examples:
Reminder: 5÷3, result:2; 10÷6, result:4
Rounding:5÷3, result:1; 10÷6, result:1
And I also want to add zeros before some results if their digits are less than 3.
I can get it done in ArcGIS by using python, reminder operator is %, rounding operator is //, and zfill function to fill zeros. How can get the same result in FME? I've read the Math Operators help document, it only has % as reminder, no rounding and zfill. I have over 600000 rows of record to calculate, when I do this in ArcGIS, the software will just crash. Please give me a hand.
Best answer by david_r
Remainder = @fmod(5,3) or 5 % 3
Rounding: @floor(@div(5,3))
Padding: StringFormatter transformer
  • Sep 27, 2018 3:34 PM UTC
bobo
  • Sep 28, 2018 6:24 PM UTC
Thank you, got it worked!
