How to get an attribute value as user parameter
  • Jun 10, 2022 4:19 PM UTC
  • 576 views
I'd like to have the value of an attribute as a user parameter.
I need to make sure tables I work with comply with a schema. The schema field names are in a CSV, imported without column headers. I aggregate the attribute which leaves me with this output:
Screenshot 2022-06-10 at 18.09.50Is it possible to get the string in col0, row 1, as the default value in a user parameter to ensure my output table conforms to the schema? Thanks!
DanAtSafe
Forum|alt.badge.img+23
  • Jun 11, 2022 12:25 AM UTC
Hi @bradosav, user parameters are read into FME before the CSV data. If you use a WorkspaceRunner after reading the CSV then you could make that value the parameter value in the child workspace.
  • Jul 6, 2022 3:23 PM UTC
thanks for the answer! I guess it's a bit convoluted to do it that way, even though it is possible.
