I have a simple workbench that reads a postgis database and outputs an excel file based on a user parameter in which the user enters a filename that filters the input table into one record. This works fine within FME, however I'd like to create a batch file that runs the workbench from the command line. The problem I have is getting the batch file to prompt for the user parameter. It just runs the workbench with the last parameter I set within FME. I'd like to be able to run the batch file and get the prompt for the parameter in the command line.
How to get a user parameter input when running workbench as a .bat file.
