How to format AutoCAD so that it is ready for FME conversion into IMDF
  • Mar 20, 2019 8:48 PM UTC
  • 142 views
Hello FME Community,
I am working on a project where I need to convert an AutoCAD .dwg file into Apple's Internal Mapping Data Format (IMDF).
The tutorial FME provides assumes you have a master drawing file. Being that I was not able to find a master drawing file for the space I am looking to model, I created my own AutoCAD file. I am not a Civil Engineer and I do not have experience in AutoCAD.
I wanted to know what steps I can take to actually modify the AutoCAD file such that FME will process it correctly and spit out the .geojson file I need to proceed with IMDF. I've heard certain terms like blocks, block attributes, layers, and properties but I don't know what exactly to do so that FME will read features out of the file.
If anyone is willing to share information or even resources that might put me on a better track, I'd appreciate it greatly!
Thanks!
daveatsafe
Forum|alt.badge.img+24
  • Mar 25, 2019 5:09 PM UTC
Hi @bsalgado98,
The master drawing file is used to more easily align building levels that may have been drawn individually, without referencing the other levels with respect to position. It can be a new file you create for this purpose, then Xref the other files into.
CAD is likely the hardest data to properly convert to IMDF, since it allows a great deal of latitude in the presentation and topology of the features, and IMDF is pretty rigid in its requirements. If it is available, I strongly recommend getting a Facilities Management version of the CAD data, since it is more likely to be in a structure more compatible with IMDF than architectural drawings.
I will contact you directly to talk to you about the specifics of how FME can help with your conversion.
