how to format all the date and time properties from a json to a specific format using python
  • Jun 30, 2017 6:38 PM UTC
  • 6 replies
  • 495 views
arthy
Forum|alt.badge.img+8
I have a json and I would like to format all the date and time attribute to a specific format using python.
_result= [{"attributes":{"OBJECTID":objectid, "ATTRIBUTE1": A1 ,  "DATE1": "%Y-%m-%dT%H:%M:%SZ",  "ATTRIBUTE3": A3,"DATE2": "%Y-%m-%dT%H:%M:%SZ", ... ,"ATTRIBUTEN": AN}}]
I would like to have
_result= [{"attributes":{"OBJECTID":objectid, "ATTRIBUTE1": A1 ,  "DATE1": "%Y-%m-%d %H:%M:%S",  "ATTRIBUTE3": A3,"DATE2": "%Y-%m-%d %H:%M:%S", ... ,"ATTRIBUTEN": AN}}]
I tried this:
import datetime
import json
def formatting_date(feature):
    array = json.loads(feature.getAttribute('_result'))
    for m in array:
        for k, v in m['attributes'].items():
            if instance (v,datetime.dateime):
                v=datetime.strptime(v,'%y-%m-%d %h:%m:%s')
    feature.setAttribute('prop_', json.dumps(array))
but it failed.
Any suggestions?
erik_jan
Forum|alt.badge.img+26
  • Jun 30, 2017 7:00 PM UTC
Can't you use the DateFormatter transformer?
That allows to set the format for multiple date attributes in one go.
  • Jun 30, 2017 7:29 PM UTC
What type of attribute is PROPOSALATTRIBUTES? Is it a list? If you don't know, inspect the feature in the Data Inspector.
Otherwise I agree with @erik_jan about using the DateFormatter, much easier.
arthy
  • Jun 30, 2017 7:51 PM UTC
@david_r,
I edited my question.
Instead of proposalattributes it should be _result which is a json array.
As I said to @erik_jan, I can use the dateformatted because I don't know how many attributes (or even their name) I will ahve in the json.
arthy
  • Jun 30, 2017 7:52 PM UTC
@erik_jan,
I don't know how many date attributes or their names I will have in that json.
That's why I would like to have something that will do the formatting dynamically
  • Jul 1, 2017 2:19 AM UTC
Hi @arthy, this script converts %Y-%m-%dT%H:%M:%SZ (e.g. "2017-01-02T03:04:05Z") to %Y-%m-%d %H:%M:%S (e.g. "2017-01-02 03:04:05").
import json, datetime
    for m in array:
            try:
                dt = datetime.datetime.strptime(v, '%Y-%m-%dT%H:%M:%SZ')
                m['attributes'][k] = dt.strftime('%Y-%m-%d %H:%M:%S')
            except:
                pass
arthy
  • Jul 4, 2017 2:45 PM UTC
    for m in array:
            try:
            except:
                pass
@takashi
Thanks very much.
This is exactly what I was looking for.
