How to find alphanumeric strings and replace them with a null value
  • Dec 23, 2021 10:44 PM UTC
  • 211 views
messagemauri
I have a column in a table with names and I want to find the ones with alphanumeric string and replace it with a null value. Apparently this is erroneous data in the table.
Sample Data in the column NAME:
GREEN-BROWN TREES --> Leave as is
FORT/STRONG -> Leave as is
PEACE RIVER --> Leave as is
3T7H8HF54FD --> This is the data I want to find and replace with Null
Greatly appreciated.
Thank you.
Best answer by redgeographics
You can do that in an AttributeManager using a Conditional Value on that attribute.
Screenshot 2021-12-24 at 09.26.58So if the attribute contains the regex \\d (any digit) it'll map to a null value, otherwise there's no action and the original value is retained.
Forum|alt.badge.img+63
messagemauri
  • Dec 24, 2021 5:22 PM UTC
Thank you @Hans van der Maarel​
