How to filter out raster (tiles) that contain only nodata?
  • Apr 30, 2018 9:00 PM UTC
  • 290 views
fmelizard
Forum|alt.badge.img+22
I'm using RasterTiler to create tiles from a larger raster. However, I noticed many resulting tiles contains only nodata values. How can I avoid writing out these tiles.
Best answer by jdh
If you use the RasterBandMinMaxExtractor, you can test if both the min and max values equal the nodata value.
jdh
Forum|alt.badge.img+41
  • Apr 30, 2018 9:05 PM UTC
xiaomengatsafe
Forum|alt.badge.img+11
If you know what the Nodata values are in different bands, you can use the RsaterBandMinMaxExtractor to extract the min and max values of each band, and then using a Tester to filter out tile features whose min and max cell value both equal the no data value of that band.
e.g.
If nodata for an numeric raster is -9999, the following test will output nodata tiles as passed:
_band{0}.min = -9999
AND
_band{0}.max = -9999
So, only connect the Failed port to the writer will give you the desired result.
