How to filter lines with endpoints in polygons for clipping and keeping only line segments outside polygons?
  • Sep 5, 2018 9:47 AM UTC
  • 6 replies
  • 150 views
isis
Participant
Forum|alt.badge.img+3
I have polylines and polygons as separate source data. A polyline that has an end in a polygon must be clipped with a polygon, leaving only part outside the polygon. At the same time, the lines thats intersects the polygons must remain unchanged.
mygis
Forum|alt.badge.img+14
  • Sep 5, 2018 10:46 AM UTC
Hi @is you can use the clipper and choose the clipper and the lines outside the polygons will be output from the "Outside" port
For the lines that intersect the polygons you can use the LineOnAreaOverlayer transformer to know which ones touch the polygons. You could use the SpatialFilter as well, but I prefer the first one.
isis
Participant
  • Participant
  • Sep 5, 2018 10:59 AM UTC
I upload a picture - only red parts of polylines must be removed.
Forum|alt.badge.img+54
  • Sep 5, 2018 11:30 AM UTC
Do you have the scenario where a polyline might start and end in different polygons and need to be clipped by both?
  • Sep 5, 2018 11:50 AM UTC
endpoints-in-polygons.fmwt
I would use a pattern matrix to determine which lines start/end within the polygon, then use that as a basis to group by in the clipper. If you have lines that start and end in different polygons, you then need to combine the clipped output so that only the portion of the line outside polygons is retained.
isis
Participant
  • Participant
  • Sep 5, 2018 12:04 PM UTC
The situation when the line starts and ends in different polygons and must be cut at both ends is possible, but is not the basic condition, because in most cases the lines start outside the polygons. Thank you for advice, @egomm .
  • Sep 5, 2018 12:13 PM UTC
I think currently this wouldn't deal correctly with the scenario where a line starts and ends in the same polygon, you would need to update the matrix to 1010F0212 1010FF212 to include this.
