How to filter features based on a substring
fmelizard
Forum|alt.badge.img+19
I want to filter my data to find features where part of an attribute matches a predefined string. How can I do that?
xiaomengatsafe
Forum|alt.badge.img+3
I can think of two potential options:
  1. Use the tester transformer with Contain Operator
  2. Use the StringSearcher if you want to perform more complex filtering by matching a substring pattern using Regular Expression
danilo_fme
Forum|alt.badge.img+45
  • July 11, 2018
Perfect answer @XiaomengAtSafe
taojunabc
Participant
  • Participant
  • July 11, 2018
Perhaps the safe company can consider adding a matching method other than the exact matching mode for the FeatureTypeFilter, such as regular expressions, like expressions, etc.
xiaomengatsafe
That's a great idea @taojunab. I've posted this idea on your behalf, and hopefully captured what you are looking for. Please add your use case and comment there to help support your idea. Don't forget to vote for it :)
taojunabc
Participant
  • Participant
  • July 12, 2018
Thank you @XiaomengAtSafe
I will vote for this idea.
