How to extrude the buffered borders of the forced 2D Shape to the original 3D Shape
  • July 31, 2017
  • 11 replies
  • 122 views
Best answer by takashi
Hi @fernando, this is an experimental workspace. It may not be perfect, but seems to work fine for at least your sample data. Hope this helps.
esrishape2none.fmwt (FME 2017.0)
danilo_fme
Forum|alt.badge.img+57
  • July 31, 2017
Hi @fernando do you have 3D polygons and would you like to extract the values borders?
  • July 31, 2017
Hi @danilo_inovacao, here a picture of my result,
The green polygons are my original shape, and the buffered border in lila. I cant get all of the border aligned with the original
danilo_fme
  • July 31, 2017
Do you have a polygon for example and can share it?
  • July 31, 2017
here the shape that Im using, ground-shape.zip
danilo_fme
  • July 31, 2017
Thanks @fernando. I used the transformer 3DBufferer and the output is:
Attached the Template file ( FMWT ).
Thanks,
Danilo - 3d.fmwt
  • July 31, 2017
Thanks,
Danilo - 3d.fmwt
Sorry, I explained myself wrong, i meant, to draped the border polygons to the original 3D shape
danilo_fme
  • July 31, 2017
Hi @fernando, with custom transformer VertexCreator you can extract the points:
Points and geometry 3D:
And now do you want to extract like line the borders? Just connect the points extracted with transformer VertexExtrator.
Thanks,
3d-vertexextractor.fmwt
  • July 31, 2017
Thanks,
I extracted already the border, but the SurfaceDraper wont completely draped the border to the original shape. I need both of them to be separated from each other, here my workspace. Thanks! geotiff-esrishape2none-trianguliert.fmwt
danilo_fme
  • July 31, 2017
I tested so many the workspace template and maked any changes in configuration, but without success, very strange problem.
  • August 2, 2017
  • August 2, 2017
Hi @takashi, thank you very much!!!! It helps a lot :)
