How to extract .zip files downloaded by HttpCaller?
  • July 31, 2018
  • 9 replies
  • 223 views
mr_fme
Forum|alt.badge.img+9
I´m using this comand:
cd / "C:\\Program Files (x86)\\WinRAR\\Rar.exe" x-y "@Value(_response_file_path)"
The file is downloaded correctly but the unzip process don´t work properly.
Thank´s
Best answer by redgeographics
The SystemCaller would be the transformer to use for that.
danilo_fme
Forum|alt.badge.img+53
  • July 31, 2018
Hi @mr_fme
I think you can use the custom transformer ZipExtractor after the HttpCaller.
Thanks,
Danilo
mr_fme
  • July 31, 2018
Hi @mr_fme
Thanks,
Danilo
Unfortunately not! I´m using 2017 version. This transformer crash my workbench. I need to use command line.
Forum|alt.badge.img+62
  • July 31, 2018
mr_fme
  • July 31, 2018
Correct!! But I need the correct command line
Does that command line you posted work ok if you run it directly in cmd?
I'd try it without the cd /, I think the SystemCaller tries to execute the whole thing as a single command.
mr_fme
  • July 31, 2018
This command run properly in CMD but not in FME:
cd C:\\Program Files (x86)\\WinRAR\\winrar x C:\\Users\\FME\\Desktop\\test_file.zip c:\\test
  • July 31, 2018
cd C:\Program Files (x86)\WinRAR\winrar x C:\Users\FME\Desktop\test_file.zip c:\test
I don't think so.
  • The leading "cd" is not necessary.
  • The file path should be quoted since the path contains spaces.
This command line should work with cmd.
"C:\Program Files (x86)\WinRAR\winrar" x C:\Users\FME\Desktop\test_file.zip c:\test
Also, when you execute the command line via the SystemCaller, you will have to quote the entire command line if a file path within it contains spaces.
""C:\Program Files (x86)\WinRAR\winrar" x C:\Users\FME\Desktop\test_file.zip c:\test"
mr_fme
  • August 1, 2018
I don't think so.
Hi @takashi
Thank´s, work properly now!! I was missing something very silly for what I saw.
  • August 1, 2018
The ZipExtractor should work in FME 2015.1.3.2+. If a translation has crashed causing by some issue in the transformer, I would have to fix it. Could you please post the log file logged when the translation crashed?
