How to extract values from comma separated list?
  • January 21, 2020
  • 342 views
Hello,
I would like to extract attributes from a text file. The texfile contains different attributes separated by comma (,). It is like:
104.474,104.474,649621.0654572968,245370.49979405673,0,0,146
I tried this regex , but it gives back . delimited values (like: 474,104)
(\\d+)(,\\s*\\d+)*
Thanks!
erik_jan
Forum|alt.badge.img+19
  • January 21, 2020
Have a look at the AttributeSplitter transformer.
After reading the text line by line, this will get you the attribute values in a list.
Then the AttributeManager can convert them to the named attributes you want.
Hope this helps.
arnold_bijlsma
Forum|alt.badge.img+14
1. Try using a CSV Reader instead of TextFile Reader
2. If still needing to use a TextFile Reader, use an AttributeSplitter instead of RegEx
